jamieb said:how often should you re-torque m.c.c.'s if at all, there seems to be mixed opinions on this subject.....help!!!
infinity said:Many people say never if the original installation was torqued properly. My old company did maintenance for an American Express computer center. An entire building filled with computer equipment. They would periodically shut down all of the PDU's and we would re-torque every CB as part of their routine maintenance. They thought it was a good idea.
brian john said:ZOG nailed it:
Terminations are historically OVER TORQUED by electricians seldom to ever under torqued. Connections are missed and not tightened but once the man with the wrench tightens he bears down with all he has.
In cases where re-torquing is recommended the value is usually less that the original torque setting.
IR and repair as necessary, torquing a bad connection does not improve the connection.
dbuckley said:If the MCCs have bolts on the end for lugs then on installation once the bolt is torqued draw a line with a sharpie across the bolt, nut, and lug. Then if the nut moves it is noticable.
Shutting down data centres for retorquing is so last century, marking the bolts and thermal imaging has made it unnecessary.
R Bob said:I was on a job the other day where a VA Power crew was connecting the line on a CT. They were using a socket and ratchet.
I asked one of the guys if they ever use a torque wrench. He laughs and says that they just crank it down until it clicks, then it's torqued!
