What is reactive power loss?
On edit: I guess I should state not the formula, but what causes the loss.
The diagram above shows a generator that provides electrical energy to a motor. If the motor is unloaded and is located a short distance from the genrator, the energy from the generator causes magnetic fields to form around the motor coils.
Since the coils of the motor are reactive, the current causes a magnetic field to expand around the coils during one portion of the alternation.
During another portion of the alternation, the magnetic field collapses, induces a voltage at the coil, and causes current from motor to flow back to the generator.
The rate which a reactive component stores energy in its magnetic field and then returns it to the source, is know as reactive power. Since it does not represent an energy loss, because there is no heat dissipation, it is sometimes called Wattless power.
