Sparky1981
PE
- Denver, CO
- Electrical/Lighting Engineer
We are installing a receptacle for a small transformer to power faucets. We would like to mount this receptacle behind an apron below the sink. To access the receptacle you would need to remove screws and remove a panel, thus not meeting "readily accessible".
The receptacle is protected by a GFCI circuit. We are connecting it to the same circuit as a receptacle above the sink. This device will be mounted on the load side of the receptacle above the sink, which will have the test and reset buttons. To me this wont require the faucet power to be readily accessible.
I am not aware of any other section of the code that would require this.
Does anybody have any experience or a section of code that tells me otherwise?
As always appreciate the brain power on this forum!
