reading amperages
AKwiring
This may be a dumb question, but can someone clarify this for me?
If I am measuring the amperage across each leg of a 2 pole 100 amp breaker and one leg reads 60 amps and one reads 50 amps is the service using 55 amps?
or 110 amps?
Can you explain?
Thank you.
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
or 110 amps?
Can you explain?
Thank you.
Neither -- it is using 60 amps one one leg and 50 amps on the other. I guess you can say it is using a maximum 60 amps.
iwire
Massachusetts
or 110 amps?
Can you explain?
Thank you.
Because the supply and loads in a panel will be more then one voltage you have to forget current (amps) and think power (watts)
A 100 amp breaker in a 120/240 volt single phase panel can supply 24,000 watts (24 KW) evenly balanced.
winnie
Springfield, MA, USA
Electric motor research
And if that breaker is supplying 60A on one leg and 50A on the other leg, then you have 60*120 + 50*120 = 13200 kva being supplied.
-Jon
480sparky
Iowegia
-Jon
Would not 50a on leg B be the same 50a on leg A, the other 10a going back through the neutral?
roger
Fl
Retired Electrician
Yes (barring stray currents) but, neutral current is not power supplied.
Roger
