zbang
- Roughly 5346 miles from Earls Court
Need another opinion on this-
A couple of months ago, a group I work with had some panels installed for outdoor event use. This is a permanent install, not temporary. All of these have an even number of 20a GFCI receptacles and few 50a 2p RV-style receptacles . Pairs of 20a outlets were installed in quad boxes with in-use bubbles, mounted to the side of the panels. OK. No problem.
When I looked inside, every single 20a receptacle on the entire site (10 panels, about 60 outlets) were installed as 2 pole MWBCs!
(I think this must have saved 20' of 12g solid per panel.)
IMHO this is, well, just stupid. At these events, you're fairly likely to trip a 20a circuit when some food vendor stacks all their coffee makers on one extension cord, and using 2-pole breakers will make it much more difficult to quickly troubleshoot things. Especially as each circuit may run a different vendor. It also leads to problems with the other vendors...
Am I off base here or were the installers either cheap, lazy, or just trying to make things difficult? (IMHO, the overall quality of install wasn't so hot, anyway.) If it were me, I'd just add the missing neutrals and remove the handle ties from the breakers (can't remember if they used them or 2p breakers), but I won't see this site for another 8 or 9 months.
Yes, I could have specified no MWBCs. On the other hand, I don't think I've ever seen anybody use them when the breaker-to-receptacle distance is less than 10'. Having the installation changed wasn't an option at the time. Most of the panels are 200a & 320a 120/240v SqD meter combos, with a couple of 200a 120/208v 3p ones.
Other than that I have to live with it... what do people think?
