QES
- California
do you have to bond to non exposed rebar to ground grid?
QES said:do you have to bond to non exposed rebar to ground grid?
If is is a service look at 250.50 and if it is a second building look at 250.32(A).got a nec section on that?
There is no option if there is 20' or more of 1/2" or larger rebar in the footing or foundation.so does the code said you must bonded the rebar? or you have the option to use the rebar as a electrode?
QES said:so does the code said you must bonded the rebar? or you have the option to use the rebar as a electrode?
