fisherelectric
- Northern Va
We have an outdoor hot tub install. The hot tub will be in a concrete floored block pit in a stone patio and surrounded by an 18" high block with stone wall. The contractor has made the pit long enough to allow room to hook it up inside the pit. The tub fits tight in the pit except where the 36" area for maintenance and wiring is. The contractor is going to put a removable wood deck over that area for access to the tub.
He also wants us to install a switched outlet in that part of the pit to plug in 2 small low voltage fountains on either side of the tub (about 5' away on either side).
My question is if the receptacle under the removable access panel is compliant with 680.22 ('08 NEC). We will bond the box and GFI protect the receptacle.
Thanks in advance for any opinions, thoughts, on this.
