Receptacle box installation
sharan
Is 2 1/2 " metal stud construction sufficient for standard duplex receptacle recessed application?
How deep is a 1900 box?
Deep enough for the outlet?
Deep enough for the wall?
There's your answer :)
You can always use a 4"sq box with an adapter ring however they make boxes that are 3 " deep. 2.5 + .5 (sheetrock)= 3 inches.
I use a bracket to span steel studs and mount my 4" boxes with mudrings on, I think they are made by caddy or b-line, it makes the box really firm for when a cord is pushed into the device.
"spreader bars"
caddy tsgb16 or tsgb24
One quick side note: I've always found that a mudring 1/8" deeper than the nominal wall thickness fits perfectly. In other words, a 5/8" ring for 1/2" drywall. That allows for the box's 8-32 screw heads and such.
I wish our guys would do that too. So many times I've had to shim the receps out when the sheetrockers get a little wild and oversize the hole.
I basically agree with Mr. Fine's idea of using 5/8" "mudrings" for 1/2" drywall. But the problem there is that the sheetrockers could easily take the time to create a little divot on the back of the gypsum board where the 8-32 screws go. Why doesn't someone get smart an use flat head screws on the boxes?
Also use 3/4" rings for 5/8" drywall. There is always a gap otherwise.
And why use "mudrings"? These are designed for plaster applications. Masonary rings have straight edges or sharp 90? angles so there is no unnecessary gap between the metal and the gypsum.
~Peter
What!! They can't even cut out around the boxes right. What makes you think they'll be able to make two divots? Seriously, that's a pipe dream?
Uh... cost. The one's you propose are about triple the cost. Millions and millions of boxes have been installed with ordinary stamped mud rings with success, so there's no reason to use a more expensive part to save another trade effort or labor.
Has anybody ever seen a drywaller take their time? One advantage to using the deeper plaster ring is that it makes it easier to find your covered up box that the careful drywaller buried. The wallboard protrudes a little.
Easily? No. Why make sheetrockers cut divots when we can just as easily buy 1/8" deeper mudrings for almost the same price with no extra effort to install them?
Secondly, why should a sheetrocker care if our mudrings stick out far enough or not? That's up to the electrician to take care of that.
