Machiavelli999
I have got a piece of equipment that came out with a L23-30P plug. That is a 600V rated, 3PH, 5 wire (3H, N, G) plug.
However, the equipment actually requires a 208/120V, 1PH, 4 wire (2H, N, G) connection. The equipment vendor claims that they have always done it this way and that they "just leave one phase connection empty". Is that acceptable per NEC code?
I was going to simply provide a L23-30R receptacle but wire it up for only 208V/120V, 1PH connection. Then maybe provide a label indicating that this outlet is only for this equipment and that one of the phases is disconnected.
It's sloppy, but I am afraid that simply taking the plug off and changing it would nullify the UL listing on the equipment.
