Why not in the wall or ceiling next to the handrail?
Or there is no wall next to the handrail. I would keep it to one side to avoid being kicked. Not a good location, IMO.Because he want's it in the stair riser.
Ok I have question that was asked of me that I do not know how to answer. The question came from my son a EE who wants to put a rec in the riser of his staircase for Christmas lights. I think he is nuts. But is there any reason you can?t do it.
The building inspector might use this. Note 'clear width'.
"311.5.1 Width.
Stairways shall not be less than 36 inches (914 mm) in clear width at all points above the permitted handrail height and below the required headroom height. Handrails shall not project more than 4.5 inches (114 mm) on either side of the stairway and the minimum clear width of the stairway at and below the handrail height, including treads and landings, shall not be less than 31.5 inches (787 mm) where a handrail is installed on one side and 27 inches (698 mm) where handrails are provided on both sides."
So he might have room at the side of the step. 31.5" minimum.
Assuming a flush mounted device it seems the BI is out of luck.
First of all the kid is a EE so he knows it all and I just don't like cutting a nice oak riser for 2 weeks out of the year. But I told him I would look in to it. Thanks for the input.
For me this is a who gives a crap situation. Install the receptacle and move on. Maybe a good place for a sillite receptacle.
What code section is that?
