DJFNEC2005
- NJ
Hi,
I know this is the place to come for answers. I did a search and have not come up with a definite answer so I am going to ask the masses for their opinions please.
I have a customer that will be installing a gas fireplace insert into an existing prefab sheet metal enclosed ceramic fireplace. There is a receptacle to tap off of to the right of the fireplace and 2 above the mantle. The unit will draw 1.5A @ 120v.
My question is has anyone ever installed a receptacle within an existing fireplace behind the insert for this purpose? What about heat buildup back there? Is the area behind the insert ok for NM cable? I'm thinking it should be BX/MC cable anyway for protection because of the penetration through the sheet metal but not sure if the heat will exceed the temperature rating of the cable.
I have seen the blowers that have a cord coming out the front to plug into a receptacle outside the fireplace but this is the first request I have had for one to be installed inside the fireplace and am just unsure of any potential violations. My first reaction to doing this just didn't feel right. This is a home in Northern NJ.
Any comments from people who have done this type of install would be appreciated.
Thanks in advance for your help.
