Bill Annett
- Wheeling, WV
- Retired ( 2020 ) City Electrical inspector
I have a situation where I need some. I did an inspection in a kitchen and they installed cut in metal boxes using Madison straps into the side of a base cabinet for an Island or Peninsula, which pots and pans will be stored. The boxes stick into the cabinet about 3 inches and are located above the shelf in the cabinet.
I said that they need to protect the box from physical damage because the pots and pans will be hitting it when they put the pots or pans on that top shelf. This is in a 6 story apartment building. They ran MC Cable and it is protected by the way it was routed.
I looked in the code book but I could not find anything about protecting the box. My common sense says that It needs protected but does the NEC require the box to be protected.
Am I wrong? Any code reference or equipment listing that would back up my common sense would be appreciated. Also any code reference that says I am wrong would also be helpful.
Thanks, Bill
Thanks, Bill
