jmsbrush
- Central Florida
Lets say you rough in a room to code. This is a very small room 6'X8'.this room has three French doors in the room. so that makes only one wall with nothing on or in it. So I installed 1 receptacle on each side of 2 of the French doors.
I didn't install any other rec near the third door because the other receptacles were within 2 feet of each side of that third door if that makes since.
It passed inspection. So I went out, to trim it out. The homeowners decided they did not want that 3rd set of French doors and had the gc take them out, frame the wall, then hung the dry wall.
Now I have a wall with no receptacle. That wall is 8', I have 2 rec near that 8 foot wall because of the other 2 French doors and the distance between those 2 are less than 12'
Will that fly? Or are they going to make install a rec in that wall now because it's more than 2' of wall space?
