curiousinspector
I am trying to get the definitions of outlet, outlets, receptacle, receptacles, and multiple receptacle straight and how they apply to some of the article 210 sections.
Part of the confusion is in the definition of receptacle. The definition mentions it being a contact device. The definition does not state that that multiple contact devices on one yolk is refered to as receptacles which it would seem that receptacles would be the plural for the multiple contact devices. It mentions that this is a multiple receptacle.
The definition of outlet adds to my confusion when trying to apply 210.
Main question is this. A piece of refrigeration equipment has a minimum circuit ampacity of 17.1 amps. A 20 amp multiple receptacle is installed to supply its factory installed 125 volt 15 ampere cord and cord cap. The maximum overcurrent protection for the equipment is 30 amperes. Is it a code violation to install the multiple receptacle on a 30 ampere breaker?
The correct definition of receptacle, receptacles, outlet, and outlets seems to be the deciding factor on applying the tables and section of 210 that pertain to this example or am I missing some other code section that would be the answer?
Thanks for any light you could shed on this for me
