J jap Senior Member Occupation Electrician Nov 5, 2024 #1 A standard duplex receptacle wired reverse polarity fed off the load side of an upstream GFI Receptacle. Would the GFI ever know the difference? I don't know that it would, and, haven't had the time to bench test that scenario. Jap>
E Eddie702 Licensed Electrician Location Western Massachusetts Occupation Electrician Nov 5, 2024 #2 No. The GFCI measure the hot amps versus the neutral amps and trips if they go out of balance.
LarryFine Master Electrician Electric Contractor Richmond VA Location Henrico County, VA Occupation Electrical Contractor Nov 5, 2024 #3 Polarity only matters to loads that care about which line is grounded, or lampholders with screw-shells.
