goldstar
- New Jersey
- Electrical Contractor
I keep running into this problem over and over again. A customer calls and says that there is no power in one of their rooms but all breakers are on. I know what the problem is just from the conversation. I get to the house and begin removing receptacles and low and behold all the wires are "stabbed" into the backs of the receptacles. And, as if that weren't bad enough, in some cases there are wires attached to the same receptacle via the screw terminals. In most cases, where the stabs are used and there are only 4 wires (2 white & 2 black) the screw terminals are not even tightened down. If you're lucky you'll find the loose wire when you pull out the receptacle or find a burnt receptacle where the wires had become loose.
I had a "go around" with someone from EC Magazine on this subject a while ago but somehow couldn't get my point across. They kept indicating that the stabs are an approved method of attachment. My gripe with this wiring method is that over time the captive hardware part of these stab connections becomes loose due to heat from loads attached. If you cascade or daisy-chain a number of receptacles (lets say 8) and use this wiring method, the load for the enrire circuit is borne by the first receptacle of that circuit. Some might argue that they run into this situation even with the screw-down method of attachment but I've got to believe that the occurrances of interrupted circuits are far less than the stab method. I also think that usnig the receptacle stab method is a fire hazard and should be addressed by the Code panel.
Again, just my opinion.
[ May 02, 2003, 05:54 AM: Message edited by: goldstar ]
