Tamper-Resistant, Duplex Grounding Receptacle. 15 amp, 125 volt. White.
FEATURES
* Meets 2008 National Electrical Code Tamper-Resistant requirements.
* Protects children: patented shutter system helps prevent improper insertion of foreign objects.
* High-impact resistant thermoplastic construction.
* Extra-long strap.
* Quickloop wire looping aid.
* Long-term blade retention.
* Longer tri-drive screws for easier 12 AWG looping.
* Extra-large circuit break-off tabs.
* Side-access push wire release.
* Ultrasonic welding of face to back body.
* Side wire accepts #12 ? #14 AWG solid wire.
* Push wire accepts #14 AWG solid only.
* Superior protection than traditional outlet caps or protection plates.
* Low profile face.
* Traditional contoured face (3232 models).
* Self-grounding models provide automatic ground clip.
If you installed the above receptacle with 12 stranded wrapped around it you would violate 110.3(B)
