I was inspecting a master bath whirlpool tub that was energized by a switched receptacle on an 110v ITE GFCI breaker.  All was testing normally when I installed my red GB GFCI tester to check polarity and got nothing... no illuminated lights at all.  Plugged the pump back in and got full force pump operation.  Opened the switch and pump went off.  Closed the switch..on.  Exercised GFI.. and it opened the circuit. Reset and checked with tester at receptacle...nothing.  Put the tick tracer on and yes... it has power, pump works, no illumination from tester.  Checked the tester, and it is ok... lit up and tripped all other GFCis.  Put the Ideal Sure Test on and nothing.  So, how can a receptacle have power and run a pump but still not energize testers?  I gave up and instructed my client to have an electrician further evaluate bc a suspect GFCI circuit on a whirlpool tub is not a good thing.
