Re: Receptacles Height
When working with NM cable, and the device is to be mounted on the baseboard, because the wallboard is already installed, staples are not required. I would leave 3 feet of wire hanging at each location for the rough, have the finish carpenter cut the holes, attach the cut-in box to the end 8 inches, make up the splices, attach the receptacle, then use little screws to fasten the box to the baseboard through the end brackets. This method eliminates 3/4 of the floor work. With today's battery screwdrivers, it would be even better.
