How many receptacles can I put on a 20 amp breaker in a single family dwelling general lighting ?
Pretty much as many as you want in 800 sq. ft.
800sq. ft x 3 watts per sq. ft. = 2400 w divide by 120 v = 20 amps.
General lighting circuits are calculated at 3 w per sq. ft. Correct?where did the 800sqft come from? or was it just an example?
So how do you know when you have too much on any individual circuit if a particular 800 square foot area is served by multiple branch circuits? Complicate that by the fact those multiple circuits maybe supply outlets in areas outside the 800 we somehow have narrowed down.Pretty much as many as you want in 800 sq. ft.
I suppose I came up with that as the OP's question was for a dwelling general lighting circuit. No SABC's, laundry, etc, were a part of the question.So how do you know when you have too much on any individual circuit if a particular 800 square foot area is served by multiple branch circuits? Complicate that by the fact those multiple circuits maybe supply outlets in areas outside the 800 we somehow have narrowed down.
How many square feet does an outdoor receptacle or even lighting outlet which is permitted to be on same circuit as many interior rooms cover?
IMO the 3VA per SF is intended to be a value to be used for feeder/service calculations, and to complicate things the SF includes areas that are to be supplied by SABC's which are already included separately in the feeder/service calculations at 1500 VA each as well as the 1500 VA laundry circuit. I do agree that if that is the intention it is not all that clear, but there is so many things that do conflict with the 3VA principle as well.
15 a ckt would be 600 sq. ft.
I think one can argue what Ron is saying. If we calculate the loads at 3 va/ sq.ft then I could see an inspector saying that you cannot have more than 600 sq. ft for a 15 amp cir. That would be like 3 large rooms 13x15 sq. ft. The problem I have with this is as soon as you install another circuit in this area for lighting then how do you calculate the sq.ft.
3 rooms that total 600 sq.ft but there is a lighting circuit in there as well--that makes it hard to do that. The NEC does say how many receptacles but rather how many circuits. If you have a 2000 sq. ft house then you would need 3va/sq.ft. 6000/1800= 4 cir. at 15 amps
