kriverswaters
When replacing a an old "Two Prong" duplex receptacle with a three prong grounded receptacle into a metal four square box(with a mud ring for mounting the receptalce),does a grounding pigtail have to be added between the receptacle and the box even though a "ground" connection is made when the duplex receptacle is screwed to the mud ring that is attached to the box? The metal box is fed with 1\2" EMT all the way from the panel
