Recept's
maxall777
Off a 30 Amp, 480 Volt bucket, What is the total number of 30 Amp recepticles you can install in parallel. Like a residential, for a 20 Amp circuit is 13 recepticles.????
Designer69 said:
where did you get that from? 13 rcpts on a 20A residential circuit.
180*13= 2340
2340/120= 19.5 amps
There has been a lot of discussion on whether this is for load calculation purposes or for practical use. For residential I think not.
Generally, a circuit of that size is specific duty. I do not know of a limitation from NEC other than 180va per.
I have put 12 on a 30 amp bucket before but this was in a food plant and it was for our one and only welder we spaced them around the floor to keep the AC connection and the welding leads as short as possible
What do you mean by a "bucket"
It seems unlikely you'd have 480 v general purpose recepts. I'd say you'd size it for the load to be served.
There is no limit to the number of residential recepticles on a circuit.
Dennis Alwon said:
180*13= 2340
2340/120= 19.5 amps
3:15am Saturday morning. "I'll make toast, you make bloody Mary's, plug it in under mine":roll:
Sorta like an MCC bucket, but without the starter stuff. Part of a modular switchboard, typically featuring fuses. Here's one that suffered a severe end of life failure.
Thanks... actually, I had heard MCC buckets referred to as buckets.
The memory is the second thing to go.
.:smile:
