GerryB
- woodbridge, ct. USA
So I am sure some of you have had this problem with new work recess cans. I think I've used most brands and they are all the same. I'm talking about the expandable hangers. It never fails there is a spot to narrow for the minimum length. Some are designed to cut, I've bent them sometimes, but this job the other day killed me. A large dining/living room where they took down the plaster ceiling because of a water leak and decided to do new lighting. The contractor left the slats up and made square hole where the lights are supposed to go. For whatever reason the stems were all to long and one side on some would fall under a joist so cutting it didn't help on that side. I told the contractor I might want to cut the last 10 in old work. But seems to me a good solution would be a design with just a flat expandable bar with holes in that you could screw under the joists instead of inside the joists. Then wherever the housing would fit you could easily mount it. Didn't they used to make them that way? I know I have seen those heavy metal bar boxes under the plaster and I thought I have seen old recess lights like that also.
