Recessed canless(wafer) lights in garage fire ceiling
Codybalzan
New User
California
Hello, I have recently purchased my first home and have been upgrading all of the lighting. Now that I am on to the garage I have a couple of questions. I have a single story home with only unused/uninsulated space above. The wall shared with the interior of the house does not extend to the roof so I am assuming the garage ceiling is dry-walled for fire proofing measures. I want to add 16-20, 6” wafer lights to the 20x22 space. Are there any special measures I have to take into consideration if this in fact a fire rated ceiling? I’m half inclined to just install them regardless. What is the worst that would happen, when I go to sell the place it is noted on the inspection report that the fire rated ceiling is compromised? When I bought the house it was already compromised and it didn’t scare me away. If anything they would probably appreciate the amount of lighting. That’s my take on it but I would appreciate any input to inform me further.
Thanks.
Use the disk lights on a standard box. The halo ones are inexpensive and look like cans much better than most models. I think they're around $9 a piece at the moment. Fire hats are expensive for normal cans and probably would be required in a garage fire rated ceiling. Might be cheaper to do the fire wall up the side if it's so desired.
You would still have penetrations with standard boxes would you not?
Thanks.
If you access to the space above that wall area needs 5/8 drywall IMHO
This has been up for discussion recently. Technically they're comprising the garage/dwelling separation and are not approved for this.
But my thought is what if there's an electrical panel in the wall of the garage/dwelling separation? Is it any different?
