tonype
- New Jersey
Did you write up the extension cord too ?
regardless of that a recessed can is, IMO, a terrible luminaire for a garage
Worse yet when not using a reflector type lamp in that particular trim style.I agree if there is living space above then that can will be an issue however, regardless of that a recessed can is, IMO, a terrible luminaire for a garage
Actually, LED trims in recessed lights work great for "high end" garages. We install them all the time.
I cant imagine how unless you put a lot in. They only shoot straight down.
Maybe your idea of a high end garage and mine are different. My idea is an very bright workshop, your idea may be a pretty storage area for fancy cars.![]()
They spread the light very well in a 8' or 9' ceiling. But yes, these garages are for pretty cars, not wood working. Like a Tesla's, Porsche's, Mercedes', Jaguar's, Shelby's, etc.
Totally different scenario and I bet there isn't an overhead door as shown.
Both garage door opener warranties NEC art. 110 and would say to move the receptacle closer to the door opener. I have run MC down the iron the opener is mounted with in order to have a recpt close enough to use the cord that comes with the opener.The ceiling is very high - power cord from opener was not long enough. I have seen this in the past. What is the correct way to power a door opener when the OEM power cord is not long enough?
Which would clearly be your liability...... I never used an extension cord... that might cause lightning to strike the garage.
