On a remodel job in the past if I had to install 4 inch recessed lights where the attic is covered with insulation I would always use new construction type recess can (doing all the wiring inside the attic), since there are no IC type 4 inch remodel type recessed cans that I know of. I have a job where I need to install 35 of them and I am kind of leaning towards using the non IC type remodel can and clear the insulation 3 inches away since there are so many of them. I would like to get your guys opinion on how you would do it.
Thanks,
Jason.
Thanks,
Jason.
