BMacky
- Foster City, CA
Anyone know of a mfr that makes a recessed, low-voltage (MR-16 or MR-11) fixture (3" to 4") that has some sort of "air-gap" where the housing makes its way through the wood material of a cabinet, and is listed for such? I see a lot of low-voltage fixtures inside cabinets, not just puck lights, but regular recessed fixtures, cut into cabinet tops for downlighting. I need to do something similar inside a false beam, and have clearance all the way around the can but want to know if the contact with the wood is avoided somehow with a sort of frame that separates the areas of contact with wood. Typical clearances on regular cans I've seen is 2 to 3".
Any takers??
Thank you !
Bob
Any takers??
Thank you !
Bob
