kevinware
- Louisville, KY
I guess I'm looking for opinions on when to walk away from a job. Here are the stats: I friend asked me to put up ceiling fans in the bedrooms of his house, total of three. The bedrooms never had a lighting outlet just a switch controlled receptacle in each room. The house was built in the mid 70's so of course it has aluminum wiring and the panel is original to the house so it is a split-bus panel. There is no open space to add circuits if needed and the neutral bus has no open terminals and some of the screws have more then one wire under it, copper and aluminum mixed. As far as my understanding of 210.12(B) I am going to have to install an arc-fault breaker for the new lighting/Fan outlet. If I start moving things around in this panel what kind of domino effect will I create? Should I pass on this one?
Please tell me your opinion??
Thanks,
Kevin
Thanks,
Kevin
