mystereons41
- Ulster County, New York, USA
Hi, as some of you may know I’m working on a project to install a meter pedestal at my land. I’ll most likely be using 500 kcmil wire and 3” conduit as the run to the build site is fairly long (300-350 ft). I’ll be using a meter / load center combo with feed through lugs. The ones I have found so far at Lowe’s have a max 2.5” or 2” knockouts. Am I allowed to reduce the 3” conduit immediately before the load center? Or do I need to find a load center with larger knockouts?
