I have a ground rod that measures 242 ohms. Measured with fall of potential testing. I want to determine what size grid or how many ground rods to get my resistance below 25 ohms.
I did a ground resistivity test and found that the ground resistance is 22885 ohm-centimeters. Using my grounding Nomograph a 5/8 th in ground rod would have to be 42ft long. This is not realistic.
I have never run into this much resistance before. The companies engineer wants to use 4 additional rods tied together with a #6.
I don't know if this is right or wrong. I am just looking for the formula to how he arrived at this number.
