Looking at tying the hots together on a terminal strip as well as neutrals on another terminal strip from two 120Vac branch circuits (same hot from 120/240V panel). Per 210.7, if the two pole disconnect is used break these two hots simultaneously is adjacent to 120V/240V panel, what labeling is required by Code (Section number please) so that people understand backfeed hazard between for the short run between two pole disconnect and 120/240V panelboard. Or is the installation itself in violation of code (Section number please).
Thanks Again
Thanks Again
