Metrics are worthless
Out of my element, dude. I have been asked to supply power to this:
Based on the name plate, i assumed this would need a 100 amp receptacle. Im now questioning this assumption. Something tells me I need to go roughly half that or less with time delay fuses to better protect the unit. Any help is greatly appreciated.
As long as we keep accepting these ridiculous labeling schemes they are going to waste our time and generate errors.
What exactly does " Input Loading Current " mean? This metric is nonsensical and off putting.
The following things are unacceptable and should be resisted violently:
Attempting to state BTU/hr ratings in watts
Not stating clearly RLA, and LRA figures
Not listing MOCP clearly
Using terms that are not easily transliterated to the English system without easy and obvious conversions offered
Being Forced into metrics in the USA when a handful of sane individuals realize what a bad idea this is.
Being forced to work with units of measure that do not make sense are are difficult to translate to those which do.
Just the fact that time is being spent on getting the correct interpretation is a commentary on how messed up our approach currently is.
The last thing we need to do is accept these kinds of metrics. We need to demand a Parallel labeling system that meets US Standards, and enforce it with an " Iron Hand."
As an aside. Seasoned HVAC Techs understand the danger of fusing 3 Phase motor loads that do not have some kind of very fast single phase protection, and circuit breakers are always preferred if possible.
