cschmid
- Northern cold country
had a couple of service calls to a mom and pop meat processor..they have a freezer unit display case style..the compressor is located on the roof and the condensing unit is located directly below the compressor in the freezer unit..on hot days it will trip out once..on days it is just mild to cool it is okay..there was a slow leak on the refrigerant so the refrigeration man put this substance in it to stop the leak..Now I believe it is over heating due to lack of cooling capacity..the refrigeration guy has them believing it is a electrical problem..I have checked everything I can think of you guys have any Ideas..i have never been there while it is tripped and the amp readings are from 8 to 11 amps..I have no idea how big the compressor is but we installed the condensing unit couple years back..all wiring looks good..
