daveselectric
- Ohio
I have been told by the Leciton tech support staff that a refrigerator motor is to strong for GFCI protection. The reason given is that the return thru the neutral is not equal to the flow thru the hot causing an iinbalance and tripping. The NEC 08 requires that unfinished basements and garage receptacles be GFCI protected. This problem can occour with a sump pump. Any ideas on how to solve this problem.
