ARTICLE 210
Branch Circuits
SECTION 210.11
Subsection 210.11(C)(4) – Add a new subsection 210.11(C)(4) to read as follows:
(4) Air-Conditioning Branch Circuit. In addition to the number of branch circuits required by other
parts of this section, an individual branch circuit shall be provided for each air-conditioning receptacle
required by 210.52(I).
SECTION 210.52
Subsection 210.52(E)(3) – Delete the Exception in its entirety.
Subsection 210.52(I) – Add a new subsection 210.52(I) to read as follows:
(I) Outlet Requirements For Residential-Type Occupancies. In addition to the requirements set forth
in subsections (A) through (H) of this section, living rooms, bedrooms, dining rooms or similar rooms
shall have at least one receptacle outlet installed for air conditioners. Such outlets shall be supplied by an
individual branch circuit.
Exception: Buildings with central air conditioning systems that serve any of the above areas shall not
require separate outlets in those areas.
That can come into play if you do have the AC unit. I think OP is asking about requirement to have dedicated AC outlets even if not known if there will be an AC in a particular window, there is no such rule in NEC regarding that.manufactures recomendations.
I think I know what he's talking about. Window ac's typically have a label that say "individual branch circuit required" or something along those lines. This is just a manufacturers boiler plate. I put no stock in it. Are we going to start running dedicated circuits for an 5 amp unit in a small bedroom? :happyno::roll:
If he's in NYC then yes.
I'm aware of NYC's requirement. I'm talking about normal places.![]()
NYC is becoming (sadly) the new "norm" :jawdrop:LOL.![]()
I was wondering specifically whether this requirement applies to bathrooms and kitchens. Is it included in that which you quoted: " In addition to the requirements set forth
individual branch circuit."
That's true you can use 15a breakers with a minimum of #12. Though the amendment does not apply to premisses with central air. Just so you knowI believe the ban is on #14 wire, not 15a breakers.
