If I have a motor that is connected to a drive that has the ability to regenerative brake and in one direction I am using the motor as a motor and sending real and reactive power to the motor to move my load. If in the reverse direction, my load is such that it begins overhauling the motor. Since it is connected to the regenerative drive, the drive pumps current back to the grid to slow down the motor and lower the DC bus voltage so it doesn't trip out.
Suppose the drive/motor are the only load connected to the service and I put a power/energy logger on it. I suppose the energy logger will show that one way the KW are positive and in the other direction the KW are negative. I assume that in both directions the reactive power is Positive. I assume that in both directions it will show that the apparent power is positive.
How would you calculate total energy billed to the customer? If apparent power is + in both directions how do you know what to subtract?
I assume the following, that the real power from the overhauling segment can be subtracted from the motoring segment. I assumed the reactive power is the same in both cases. I guess this is like a real world case of complex algebra: Smotoring = Pmotoring + jQmotoring; Sov.haul = Pov.haul + jQov.haul
Smotoring + Sov.haul = (Pmotoring+ Pov.haul) + (jQmotoring+ jQov.haul)
