I'm working with a Mitsubishi Inverter FR-D700.
The situation is a seasonal usage situation, only being used during the summer months. The VFD worked great all last summer.
In the fall it was removed from its outdoor location and put into storage in a room temperature location so it wasn't in the cold.
I re-installed it a couple of weeks ago. All the previous parameters settings were saved and everything seemed to work fine.
Now they are having issues with the motor stalling out during usage.
VFD is giving the fault code for "Regenerative Overvoltage Trip During Constant Speed".
A parameter setting, "Stall Preventative Operation Level" controls a setting for this, adjustable from 0-200%.
The VFD has the factory default setting at 150%.
I'm not very knowledgeable about VFD's.
I'd like to think about adjusting this setting but just not sure.
I'm not aware of anything that has changed in the setup and usage of the motor from last summer to this summer. It sounds like the load has remained constant from last summer to this summer.
I'm looking for input if anyone has knowledge about this situation.
What are the results of adjusting this parameter either up or down...?
Thanks
Thanks
