russellroberts
- Georgia
I was asked this question and I didn't have a ready answer other than I thought it would be a code violation.
The question was: "Why is it a problem to reground the grounded conductor downstream of the first disconnect"? Now this would be in a residential setting.
I know it's permitted in 250.32 at an outbuilding.
It's not a question of rebonding,but the examples were to take a recep,break the grounded conductor,take a wire outside and drive a ground rod,or to take a wire from a subpanel neutral buss to an outside ground rod,given that the subpanel has a 4 wire feeder and the neutral is isolated from the egc per code.
I would guess this would cause potential difference problems.
Code aside,what are the problems with such an arrangement?
And no, I'm not going to do this,I only want to have a good answer ready.
Thanks for any help. Russell
