Yes, also because the NEC takes into consideration how cables are manufactured.Per 200.7(C)(1), am I correct in that a 2-conductor NM cable with ground be used to serve a 240V outlet where the white is reidentified as a phase conductor?
I'll use liquid tape to re-identify.Yes... reidentify... don't be lazy. It sucks opening a box and seeing a useable black and white wire only to meter it and discover it's 240V. If you don't like tape... take a sharpie to it.
I usually use a Sharpie, which also provides color choices. A small notch or hole in the tip makes it easier.
