Shouldn't matter to the hazardous location rating, and should run cooler than the incandescent, but as golddigger mentions enclosed CFL's do have heat issues that effect life of the CFL.
To expand on my original comment somewhat, we can look at the path by which heat leaves the fixture.
The incandescent bulb gets very hot and mostly by convection transfers heat to the air. If the air is very hot, that will still not be a major issue for the life of the bulb.
That heated air transfers heat to the body of the fixture, which moves it by conduction (low temperature differential) to the outside of the fixture, possibly a finned heat sink and from there to the surrounding air.
When you put in the CFL, there is less heat to be rejected, but since the CFL ballast has to transfer heat to the air which then has to transfer heat to the fixture, that air will get a lot hotter than if the CFL were sitting in freely moving ambient air. The fact that the outside of the fixture will be cooler and that the air temperature inside will be lower than with an incanescent, does not do the overheated CFL ballast any good. It is still hotter than it wants to be.
The CFLs that are designed for air tight enclosures (if you can find them) use more expensive components in their electronics that can survive a higher temperature. They do not have any magic way of running cooler in that environment, they are just built to work with it.
