Kilowatt#76
- Fort Mill, SC
- Electrical Designer
Hi, I'm designing a lift station for a waster water treatment plant and originally there was a PLC but now it will be controlled with relay logic. I have a power fail relay that will be used in conjunction with a time delay relay. They do not want the pumps to start up right away after power is restored, there needs to be a 15 second delay. Any ideas on how the best way to do this? The coil of the power fail relay will be energized all the time when there is power(120VAC), once the power goes out the coil is de-energized. I just can't figure out which set of contacts to use? (N.O./N.C.) with the on delay relay(15 sec.) Any help would be much appreciated. Thanks!
Kilowatt#76
Kilowatt#76
