Relays
I am wiring a PLC to VFD. When wiring to the 24 volt relays is white or black the common. I know this is a silly question but my mind is going a thousand miles an hour. I know on a switch Black is common but.....This is eluding me.
Typically, in 24V signaling field wiring, white is grounded (or negative for ungrounded DC), black is ungrounded (or positive).
I say typically because I don't know which, if any standard specifies such. More often than not in internal equipment wiring, it's the other way around (at least it was in my learning years :huh:).
In controls
Black = line voltage
Red = hot control voltage
White = neutral
Green = ground
Blue = DC voltage ( I use a wire ends red + Blk - )
Try not to use word common sometime it is used for neutral
In controls
White = neutral
Green = ground
This is for control panels and machinery under UL (508?) or NFPA 79... AFAIK.
Do you know of any standard for field wiring?
