12valve
New User
- California
- Electro mechanic
Have a Honda 8500 generator and installed a reliance transfer switch. Even in the off position the breaker on the generator trips. Using 240 4 prong connector.
It is wired to a sub panel with a separate neutral and ground bar, wired accordingly.
Have the ground wire from the exterior plug connected to the ground wire that goes to the sub panel
Ohm checked the wiring to the sub panel no shorts, verified from the plug on the generator to the transfer switch is wired correctly.
Thank you
Thank you
