Riograndeelectric
- Lakewood Colorado
A job I am going to be working on to correct some problems from the previous hack. On a 4plex unit each tenent has there own panel and meter. The building was built in the 1950s. There is no main breaker on the tenets panels. The tenet panels are located inside the kitchen of each unit. The panel is pushmatic MLO panels.
In one of the units, the panel was relocated and the feeder spliced in the attic and new home runs ran to reefed existing circuits. This is a 3 wire service. Feeders run in conduit. When the panel was relocated, should a main breaker have been installed and this panel treated as a sub panel and neutral not boned to the can? Would this also not put the main service in jeopardy of having to be rewired? The service is set up with overhead service going to a 4x4x24 3r gutter with 4 meter tapped off the service conductors.
I would also think that since they ran new homeruns to existing lights and recps that AFCI'S would now be required
