MNSparky
- Minneapolis, MN
- Electrical Contractor - 2023 NEC
Hello all, I need some advise on a job I looked at and will be bidding. The bulk of my experience is residiential and light commercial remodeling. I haven't done a lot with new or moving commercial services.
Here's what I have: this building has three 150A 3ph 120/208v services with three separate meters mounted on interior walls in what used to be three separate units. The building is being bought and turned into one space. They are planning on demoing out the entire inside of the building and reorganizing the interior walls, so the three services need to go away. They are all fed from the transformer in the picture under the building in 2-1/2" PVC.
What I need to do is mount a 400A CT on the outside of the building to the left of the transformer with MCB panels on the other side of the wall. My question is can I surface mount pipe on the exterior from the CT to the side of the POCO xfmr? I've never seen it done like this, and I've never seen the insides of one of these larger transformers so I don't know if there's room on the sides for me to come in. Xcel Energy is the POCO.
My other option is to cut the asphalt outside where the three 2-1/2" pipes enter the building and intercept them. I could turn them up into the CT at that point, but I'd have to pay someone to cut and patch the asphalt.
Any insight, experience or thoughts in this area would be greatly appreciated. Thanks!
