ramsy
NoFixNoPay Electric
- LA basin, CA
- Service Electrician
Remodel Box Fireplace - This is Why Residential Remodels VOID Claims
Plug-power failure traced to this box.
6-different cables, half Aluminum, half copper.
No listed means used for terminations, thru-out property.
Burn-damage in contact with insulation behind box. Amazing it didn't burn down yet.
Elsewhere, DIY mobile-home owner restored power to lights, by stringing lamp cord along walls between switches and plugs.
Last lines of my invoice reads:
9) New AFCI Outlet does not solve fire hazard occupancy with demonstrated additions that repeatedly defeat fire & safety codes
10) Aluminum wiring modified by unqualified persons has created a fire hazard that should be abated before occupancy
11) Today’s use of listed means, to repair a few outlets, does not remove premises hazard that should be completely abated
12) No Warranty for temporary repair of Al wiring that should be completely abated, with all hazardous additions identified
New box was moved several inches up wall before undamaged conductors were available to terminate with listed means.
