WGEC
- United States
I have a few existing generator installations where I need to install a new remote E-Stop switch. A few are Kohler 40kw units with existing E-Stops on the genny itself. Those are easy because the circuit is simply a 2 wire normally closed, that I can extend into the building and terminate to the new switch in series.
Other sites have Generac units with NO existing E-Stop buttons. They have the typical OFF/Manual/AUTO selector switch, and I successfully installed the remote E-Stop button by breaking the wire that comes off of the Auto and Manual terminal on the switch, and running it through the NC contacts on the E Stop. I am wondering if this is the best way to do this?
Alternatively, should I break the control circuit before it enters the selector switch? I tested this, and it does shut down the genny.
What has me concerned is that there is actually a wire from the OFF position terminal on the selector switch, that terminates to a PCB and a terminal strip. So my E Stop button is not exactly duplicating the OFF position of the switch, rather just breaking the ON signal. Is this acceptable to do? What function does this OFF signal have?
Thanks in advance!
Thanks in advance!
