pressurized gas pipe, two wire, K&T, afci
To replace an existing ceiling fixture hanging from a pressurized gas pipe hickey, it would be required to:
use an approved box
abandon the old wiring
pull a new circuit w/grnd
install an afci cb
recommend to depressurize and cut out old gas pipe
is this not a hardship?
I can remove the fixture, rebuild it and hang it back on the hickey.
but then it's my liability.
I we put the question of the gas pipe aside, for clarity,
replacing k&t lighting fixtures requires
use an approved box
install an afci cb
under what circumstances could the existing wiring be preserved?
only if the existing fixture is rebuit and reinstalled, if it was listed - or needed to be listed - at the time.
use an approved box
install an afci cb
use an approved box
install an afci cb
