GG
- Ft.Worth, T.X.
Hello fellow sparkys. I was on a bid today where the plumber was already there and He was giving the customer a bid for some plumbing pipe that he said needed to be replaced. He was the first plumber/salesman I have seen in a suit and tie. :roll: Anyway he informed me that the customers plumbing pipe had major "Electrolysis" damage from current traveling on the plumbing pipe and that I was to remove the CW ground and NOT reconnect it. That didn't sound like a solution to the problem so I asked him what would happen if I clamped my meter around the water pipe, shouldn't I read amperage flowing on the pipe causing the electrolysis? He said you you?sure will. Well needless to say I didn't get any amperage at all and no voltage at all with my meter on the water pipe. So what gives? Is this some new sales pitch they give the homeowner so they can replace a bunch of water pipe that has just corroded due to age? Is there such a thing as electrolysis? Should I listen to him and not reconnect the cold water ground?
