Removing ballasts in a direct wire retrofit
Code to remove ballasts?
  • yes
    Votes: 1 100.0%
  • no
    Votes: 0 0.0%
  • Total voters
    1
solis
It is good practice but is it NEC code that requires he ballasts to be removed when retrofitting fixtures to direct wire LED lamps?
It's good practice is your answer. It takes 10sec, why is this an issue?
If you are retrofitting an entire facility disposal becomes more of a significant issue vs abandoning in place.
If you had some agreement to dispose of them then you probably should do so.
